20 Most Recent
Iwill XP4evo Barebone Questions & Answers
Need a CD with drivers that came together with Iwill xp4evo. Anyone has it?
The vast majority [I won't say all but I never found one yet that wasn't] of websites offering drivers for this and other outdated devices are scam sites. To be avoided at all costs. Some of them attempt installing malware and trojans just be clicking the link to get to them.
The best way I have found to dig up unsupported drivers, etc, for devices where the manufacturer has gone the way of all things is to put a "wanted" ad in "Craig's List".
With any luck someone else with the device that has a disk will see the ad and contact you.
This unfortunately is not only the best way but likely the only way.
There use to be legitimate sites to find all manner of drivers but the internets has become a place not for the naive and trusting, full of landmines to step on when looking for such things.
If you are going to look have a very good firewall and virus/malware detection software.
Good luck.
Video & Sound drivers for my Iwill XP4
I can not find information on the motherboard specifically and whatother chips are on the board but this is where you can find chipsetdrivers for the main intel i845GV chipset.
http://www.intel.com/support/chipsets/sb/CS-009236.htm
What is the light blue plugin in back of system
Green is typically your standard speakers. Blue can be programed to be what you want it to be but is typically your stereo line in I am pretty sure.
On my system it is the center channel.
GUYZ PLZ HELP ME..IM REALLY HAVING TROUBLE WHERE I
Here's a site that lists the video drivers. Some other driver sites come up from a Google search but the mainly seem to offer the BIOS and not much else. Iwill seems to be gone, so there's no manufacturer's site to check.
Hope this helps a little. Thanks for using Fixya!
I tried to install my video card on the Iwill
make sure to check your bios is up to date check bios to see if all the pci slots are enabled and check
*********** board for a jumper if the system has onboard video sometimes you have to disable the on board video by setting the jumper to disable also sometimes in the bios there is a setting to set default video card to pci just dig around and se what you can find... if all that dosn't work these little form factor systems usualy have very limited amount of power it may be that your power supply may just not be pushing enough to run the card
I installed XP service pack 2 and now the video
Hello there: Please go to the manufactur's web site of the video card and check for a update
also i recommend going to
www.radarsync.com this is a totally free driver update utility.
once it is loaded on the computer and you begin the scan it will find all of the drivers that need to be updated and give you the list and let you choose which one to update and it is all FREE I
I have used this utility on several of my computers and it has done wonders for me ok so please try this. and dont forget to rate this solution for me.
best regards
michael
(USN) RETIRED
My XP4evo don't boot + paintful alarm
If when you try and switch it on, you get a long system beep of about 4 seconds, a pause, then that beep again - meanwhile the monitor stays blank, then that happened to me recently. It happened after I put different memory in it, and was because i hadn't pushed the new ram in firmly enough. It's partly a guess, but either your ram might have somehow come loose? or maybe the memory is knackered. Make sure you only get 184 pin 266mhz pc2100 memory, as anything newer won't work.
Hope that helps.
Motherboard
You will need to find the model number of your board to determine the processor socket type.
When you know the socket type then the mobo you need will more than likely be a mini atx board, but when you find the model and search google it will tell you the 'Form Factor Type'.
