20 Most Recent
Vivitar ViviCam 5050 Digital Camera Questions & Answers
How do I put photo's onto the computer from my
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I have a Vivitar Vivicam 5050 black and I use 2
Please try and see if you are able to get high rating cells with higher mAh specified on the battery. Check for rating that are more than the one's that is used presently or use a different type/composition of the battery like Li-Ion.
The Vivitar Vivicam 5050 is notorious for eating up battery life. But first off, try to check for any corrosion inside the battery compartment. If there is none, I would suggest that you use alkalines or better yet, rechargeable batteries to make it more cost effective.
My vivicam 5050 camera says
It is possible that there is a fault, or that the battery connections in the camera are dirty or corroded, but digital cameras are famously demanding on batteries. You must use good alkaline batteries or better, a set of high capacity NiMH recharegables. Zinc or "long life" batteries just aren't up to the task.
New rechargeable batteries are supplied only partially charged. You need to charge them fully before use.
