20 Most Recent Kenmore 64992 Electric Dryer Questions & Answers
We had an older dryer, and it got to the point
if you have a volt meter u can check power coming in should b 220 volt put one meter leave on black wire an the other on red wire meter should read 220 volt an if u go front black to white it should read 110 votl u could have a bad outlet dose outlet look like it been burn if best if you dont know how read meter to just call your appliance repair service ok be safe an turn power off to dry b4 you start test it out ok hope this help you out
6/14/2017 12:16:07 AM • Kenmore 64992... • Answered on Jun 14, 2017
How can I repair dryer that will not heat?
Either the heating element or thermostat is faulty, both can be tested with a multimeter. Can normally be accessed by removing the back and top off the machine, disconnect first and stay away from the capacitor can give you a nasty shock.Check internet for spares.hope this helps
4/19/2012 1:42:53 PM • Kenmore 64992... • Answered on Apr 19, 2012
Dryer will not start ., only get a click when you
Sounds like a failed thermal fuse and unit got too hot and this problem must be address to ensure that it will not happen again. Check you venting system to ensure proper air flow...
4/2/2011 5:46:47 PM • Kenmore 64992... • Answered on Apr 02, 2011
I have a 649943 dryer and lint screen is on top,
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
3/4/2011 2:01:11 AM • Kenmore 64992... • Answered on Mar 04, 2011
Circut breaker turned off and
Be sure you have 220 volts at the outlet. If you do check voltage on the power cord inside the machine. Be sure the timer is set correct and check the start switch.Does the motor run? If the motor runs and the drum don't turn may be the belt broken or slipped off the pulley. If motor don't run check voltage to motor if you have voltage most likely the motor is bad it can be checked with an ohm meter. Last resort could be timer. Hope some of this helps.
1/2/2011 7:03:03 AM • Kenmore 64992... • Answered on Jan 02, 2011
My kenmore 64992 gets too
Something must be rubbing.
10/14/2010 4:14:01 AM • Kenmore 64992... • Answered on Oct 14, 2010
My dryer (kenmore elite model 110.64992300) wont
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
5/26/2010 2:35:37 AM • Kenmore 64992... • Answered on May 26, 2010
Dryer quits when you let go of the starter button
The relay needs to be replaced.
4/28/2010 3:07:22 AM • Kenmore 64992... • Answered on Apr 28, 2010
NO HEAT ON KENMORE ELEC. DRYER MOD. 110.64992300
There could be a number of problems with your dryer causing it not to heat. Here is a tip that I wrote about your problem...
Heatman101
3/10/2010 12:38:33 AM • Kenmore 64992... • Answered on Mar 10, 2010
Kenmore, model#96589210, was running but not
you need chek door switch is conected.
10/6/2009 6:46:48 PM • Kenmore 64992... • Answered on Oct 06, 2009
Schematic model 110.64992300
Schematic is either on the inside of the back panel or front panel.
Eric
6/20/2009 1:37:01 PM • Kenmore 64992... • Answered on Jun 20, 2009
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
5/8/2009 1:26:50 AM • Kenmore 64992... • Answered on May 08, 2009
The dryer makes a strange buzzing sound when u try to start it
1) First thing to check, can you move the drum by hand? if not the motor or drum bearings may have seized or collapsed.
2)Have you looked to see if te drive belts still on?
3) If you can turn the drum by hand- start the dryer, open the door then turn the drum as fast as you can by hand and quickly colse the door if it now tumbles you need a new motor start capacitor.
if you have no lucjk get back to me ASAP cheers
3/24/2009 9:41:45 PM • Kenmore 64992... • Answered on Mar 24, 2009
Dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
1/4/2009 5:10:08 PM • Kenmore 64992... • Answered on Jan 04, 2009
Kenmore model #86982800
check power cord connections for tightness with the power OFF
5/8/2008 8:23:53 PM • Kenmore 64992... • Answered on May 08, 2008
2answers
Dryer
Is your vents clean??Assuming it's electric!! If yes....Unplug unit!!!!! and pull away from the wall so you can get behind it.Remove back cover.1/4 in. screws.On the heater cover you will see the high limit switch(black button like piece with two wires connected to it.Unplug the wires from this piece.Check continuity.(Multi meter)If you don't have it the high limit is bad.Local Appliance store part.
11/21/2007 2:25:57 AM • Kenmore 64992... • Answered on Nov 21, 2007
2answers
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
4/23/2024 11:52:33 AM • Kenmore Dryers • Answered 2 days ago
2answers
Trying to find out how much part #7 on the exploded view of the Kenmore elite electric dryer model 110.2808 is? It is a motor.
110.2808 is an incomplete model number. Motors are typically $140 to $180 USD https://www.easyapplianceparts.ca/PartInfo.aspx?inventory=334304&SourceCode=18 This is is a typical Kenmore model designation and is probably the matching washer to your dryer. Yours is missing 4 numbers. Label in the back, label on the door frame, mentioned on the manual.
Model # 11028081700 Official Kenmore Elite washer
https://www.google.com/search?q=Kenmore+elite+electric+dryer+110.2808 ..
2/23/2024 6:44:28 PM • Kenmore Dryers • Answered on Feb 23, 2024
Is it possible to reverse the direction that the door opens on Kenmore Elite Quietpak 4?
Yes, it looks like you can. Don't forget though that you have to get inside and move the door switch. https://www.google.com/search?q=Kenmore+Elite+Quietpak+4+reverse+door ..
1/26/2024 12:16:00 AM • Kenmore Dryers • Answered on Jan 26, 2024
Kenmore 64992 Electric Dryer Logo
Popular Tags
21 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
dryer wont turn back
  • Dryers
