20 Most Recent
AKG Perception 200 Microphone Questions & Answers
AKG perception 200 microphone won't
You cannot use the AKG 200 unless you use a preamp that will supply the +48 volt Phantom power required by this and most condenser microphones. The Zoom has condenser mics itself, but does NOT source the Phantom power for external use, and the internal voltage it uses on its own condenser type mics is much lower that that required by the AKG 200.
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip.
Good Luck
Creates excessive noise with no signal
Could you swap with a different mic so you could be sure if the line/cable are allright or confirm that the mic is defective... Also when repairing a mic, 90% of problems come from the connector welds. Use a small flat glasses screwdriver and have a look at the weld of the xlr connector from the inside...
Microphone cuts out
If you tried other cords and other PAs the problem might be in the jack where the cord plugs into the mike.
[email protected] might also be able to give you more info.
I have an issue with my AKG wireless were when i turn my headphones on it blinks blue and does not connect to my laptop if anyone could tell me how to fix it that will be great
Posted by Stephen Chiarchiaro on Sep 13, 2019
Hi Lemon Juice gaming, indicate brand, model and type of equipment and the headphones you are commenting on, also through which medium you are connecting the headphones and the computer, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Lemon Juice gaming, indica marca, modelo y tipo de equipo y los auriculares que estas comentando, tambi?n a trav?s de que medio te estas conectando los auriculares y la computadora, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
9/13/2022 5:36:27 AM •
AKG Audio...
Answered
on Sep 13, 2022
