20 Most Recent
Omega BL460S 3 Peak Horse Power Commercial Blender, Variable Speed with Pulse, 64-Ounce, Silver Questions & Answers
Breville Antony Worrall Thompson BL3 Blender user manual
Olabisi. It is better to create your own question rather than tagging a 13 year old question in the area where you ask the OP for further information before committing to an answer.
Stir function runs the blades at a much slower speed to incorporate ingredients slowly.
https://www.kitchenaid.com/pinch-of-help...
STIR. To stir ingredients in a blender, start with a low, slow speed and gradually increase it to a medium speed. Blend until ingredients are completely combined.
Different Blender Settings and What They Do - KitchenAid
3/26/2024 4:25:22 AM •
Blenders
Answered
on Mar 26, 2024
My B and D BL5000 blender doesn't stop when I press the STOP button. The motor goes when the cord is plugged in. Is this repairable? How? I have looked at the screws to get at it
the lock/unlock button on the Cuisinart Smart Stick CSB-75 blender may not stay locked when pressed in. The solution is to hold the blender in the palm of your dominant hand, press the low or high button and hold, then push and release the lock button on top with a finger on your other hand. The blender motor should start as soon as you push the lock button down and stay running until you release the high or low button.
However, fix.com offers OEM Black and Decker blender parts and accessories, including rubber gaskets, jar bases, measuring cup lid inserts, and blade assemblies. You may want to check if the parts you need are available and replaceable.
If you are unable to repair the blender yourself, you can contact Black and Decker customer service for assistance. They may be able to provide you with additional information on how to repair your blender or direct you to a local repair shop.
1/26/2024 4:05:54 AM •
Blenders
Answered
on Jan 26, 2024
What is the best blender for making smoothies with frozen fruit?
This looks Spammy, but the answer is Vitamix.Yogurt or liquid first and fruit on top and let rip!A blender is the only machine in your kitchen that can produce a beverage from chunks of ice and fruit in less than 60 seconds. And no other blender we've tested since 2012 can reliably make silky soups, spoon-thick smoothies, and stable emulsifications like the
Vitamix 5200. Yes, this model is pricey, but we think its powerful motor, nuanced controls, and long-lasting reliability make it worth the investment...
8/11/2023 6:32:01 PM •
Blenders
Answered
on Aug 11, 2023
Waring Pro MBB Blender- blade too tight
I was just able to fix mine. You'll need the following: two wrenches (almost any type), steel wool, and vegetable oil.
1. Clamp the hexagonal nut inside the bottom of the pitcher with one
wrench and place the jaws of the other wrench between the "spokes" of
the wheel at the outside bottom of the pitcher.
2. Turn either counter-clockwise until the hex nut comes off. At this
point, you should be able to pull the bottom piece out from the bottom.
Pay attention to the order and orientation of the parts inside the
pitcher as they may fall out now.
3. Dry off the shaft and rub it with some ordinary steel wool (think SOS pads).
4. Twist a small amount of the steel wool and run it back and forth through the hole the shaft goes through.
5. Wipe both clean with a clean cloth or napkin.
6. Rub a little vegetable oil on the shaft.
7. Place the shaft back in the hole and test the movement. It should be like new again.
8. Reassemble the blender.
Hope this helps,
John
4/23/2023 4:56:11 PM •
Blenders
Answered
on Apr 23, 2023
