20 Most Recent Omega BMJ330 Mega Mouth Juicer Questions & Answers
0answers
Wont turn on
Be the first to answer 3/18/2014 7:30:20 PM • Omega BMJ330... • Posted on Mar 18, 2014Be the first to answer
What fuse should I have in my nutribullet 600watt 240 volts
At 600W and Voltage(rms) of 240V gives Current(rms) of 2.5amps, so max current would be about 1.5x2.5 or 3.75amps. A 5amp fuse should suffice in that case.
3/9/2023 10:19:42 PM • Blenders • Answered on Mar 09, 2023
Farberware cordless blender will not charge. Tried different outlets. Haven't even had it 2 months
It is possible that the charger for your Farberware blender is not functioning correctly. I suggest contacting Farberware for a replacement charger or repair instructions, as this is likely to be the best way to resolve the issue.
1/29/2023 11:14:53 PM • Blenders • Answered on Jan 29, 2023
Ronson on stick blender 8342 motor coupler
If you need a replacement motor coupler for your Ronson 8342 stick blender, there are a few options you can try:
  1. Check with the manufacturer: Contact Ronson customer support and inquire about the availability of a replacement motor coupler for your specific model of stick blender. They may be able to provide you with a replacement part or direct you to a authorized distributor.
  2. Check online retailers: Look for online retailers that sell parts for small appliances, such as Amazon or eBay. You may be able to find a replacement motor coupler for your Ronson stick blender.
  3. Check with local appliance repair shops: Local appliance repair shops may carry the replacement parts you need or have the contacts to help you find them.
It's worth noting that finding replacement parts for old appliances can be difficult and that's why it's always better to check with the manufacturer first. Also, you might want to have the model and serial number of your stick blender when reaching out to the manufacturer or other suppliers, as it will help them to identify the correct parts for your specific unit.
1/14/2023 4:00:34 PM • Blenders • Answered on Jan 14, 2023
2answers
Replace oster kitchen center base drive part
I'am the guy who posted the comment I found out how to do this.
There are 2 possible solutions the 2nd is not pretty, hope the first works for you it didn't for me.
1- The motor must be lock up, by placing a thin screwdriver through the holes in the base into the fan down into the motor,holding the screwdriver, remove the square drive from the top.The part you are trying to remove actually is screwed into a gear in the gear box, you will need a spanner wrench,(sometimes a strong pair of long nose pliers will work, engage the spanner holes,hold the screwdriver ,and try to unsrew it, you may need someone to hold the screwdriver,because it takes a lot of force to loosen it.These are regular threads,and unscew counter clockwise.
2- if #1 doesn't work-this will- but its not so pretty.The motor assembly attached to the gear box will have to be removed,it will come out as one piece
Remove the bottom plate,unplug the white wire from the speed control,and the blue- white wire from the board,also you will have to remove one of the brushes with the white -blk lead.
Now you will have to actually break off of the top plastic(bakelite)by whatever means you dream up (I actually used a small wood chisel to score a line, and crack it) once its cracked, it breaks apart easily.Once thats done turn it over and remove the four screws holding the gear box to the housing you will now be able to remove the gear-box motor assembly.
Remove the 3 screws from the top of the gear box pry the box open,remove the gear with the piece that needs to be replaced,now you need to get the piece unscrewed from the gear.I did this by locking the nurled end into a vise, and very carefully grabing the gear teeth with large channel locks(if you think of a better way thats great)it work for me,but I was very concerned about the gear teeth,you can't slip.
Try the new piece to make sure it sets all the way down to the bottom of the gear(it must or your head will be to high ,and won't lock down)if all is well,make sure everything is greased,and start re-assembly, the new coupler ,and the square drive will be the last 2 pieces assembled from the top, once again locking the motor with a small screwdriver.
12/13/2022 12:22:39 AM • Blenders • Answered on Dec 13, 2022
5answers
Why is my ninja blender not spinning ? I've had it for a while an used it many times how can I fix it?
Sounds like the gear is stripped inside
11/17/2022 2:19:47 AM • Blenders • Answered on Nov 17, 2022
Please my silver crest blender produces light sparkles when blending. Any help ?
It is probably due to a bad connection in the motor. You will need to take it apart and check the connections.
11/5/2022 12:55:54 PM • Blenders • Answered on Nov 05, 2022
2answers
Ninja Blender 1100 starts then stops almost immediately, is there a way to fix this?
It Could Be a Number of Things.. It's most likely that the electrical Wire Could Have a Shortage, If it cuts off again Try gently Wiggling the Electrical Wire in a Number of Directions If it cuts on and off while your fidgeting with it, you've found your Problem! A quick fix would be to Adjust the wire In the position it would cut on the strongest, wrap the cord with Tape to Keep the wire in that Position, this will Prevent it from shorting again. Either that or you simply put too much product in the Blender with an inadequate amount of liquid.
10/16/2022 6:43:20 PM • Blenders • Answered on Oct 16, 2022
How to open the blender case?
Google make model disassembly. all question s need 'make model (what it is)'.
9/4/2022 7:49:07 PM • Blenders • Answered on Sep 04, 2022
Margaritaville Bali DM3500. Why doesn't it blend?
I have the Margaritaville Bali DM3500 and the motor has gone out on the self Serv section What is the part number and how do I order a new one ?
7/26/2022 9:46:35 PM • Blenders • Answered on Jul 26, 2022
Can't fix my new 15981 Blender Jug on my Vitamix 5000?
Question edited for clarity, and 'Vitamix' one word. Is it the right one? does it look like this? https://www.vortexrestaurantequipment.ca/product/vitamix-15981-32-oz-advance-complete-blender-container/ It should just press into place. https://www.google.com/search?q=Vitamix+15981+for+vitamix+5000
7/7/2022 7:06:22 PM • Blenders • Answered on Jul 07, 2022
Kitchen appliance leaving soot marks on bench
I would get it repaired first. That may avoid a fire!
6/15/2022 7:01:16 AM • Blenders • Answered on Jun 15, 2022
I have the Margaritaville Bahamas drink maker. The auto blend/crush would only blend, not crush the ice. The manual button works fine. Can it be fixed please? Thanks.
Question edited for clarity. Question moved from Refrigerators. Contact the company direct with a view to having it repaired or replaced under warranty. https://www.margaritavillecargo.com/bahamas.html ..
5/1/2022 5:15:20 PM • Blenders • Answered on May 01, 2022
Omega BMJ330 Mega Mouth Juicer Logo
2 questions posted
Top Omega Blenders Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you an Omega Blender Expert? Answer questions, earn points and help others
View Most Popular
Omega Blenders
  • Omega Blenders
Most Popular Question
please send me manual books in
  • Blenders
