20 Most Recent
Samsung NE595R0ABBB 5.9 cu. ft. Large Capacity Electric Range - Black Questions & Answers
I Need help to convert the range from 110v to 220v.
Hello Euardo,
I am glad you have added the extra info.
I think you need to replace the clock (with the timer) for one of 110 v 50 Hz, but I am afraid it will be hard to find that.
I would advise, take contact with Samsung.
Kind regards, Dik
3/6/2018 7:56:04 PM •
Samsung...
Answered
on Mar 06, 2018
My Samsung gas range stove top won't stop periodically beeping and there's no error codes
If your Samsung gas range stove top is periodically beeping and there are no error codes, it is likely that the burner is not properly connected. Make sure that the burner is securely connected to the stove top and that the power switch is in the "on" position. If the problem persists, you may need to replace the burner or contact the manufacturer for assistance.
Flame on our new Samsung gas stove too high... simmer is still boiling everything
It is generally not possible to reduce the flow of gas to the burners on a stove top. The burners on a gas stove are designed to operate at a specific flow rate, and reducing the flow of gas to the burners could affect their performance. If you are concerned about the amount of gas being used by your stove top burners, there are a few things you can try:
- Make sure the burners are properly adjusted so that the flame is the correct size for the pan you are using.
- Use a pan with a flat bottom that is the same size as the burner. This will help ensure that the burner is being used efficiently.
- Turn the burner off as soon as the pan is hot enough. This will help conserve gas and reduce your energy usage.
If you are still concerned about the amount of gas being used by your stove top burners, you may want to consider switching to an electric stove or using a gas stove with a more efficient design.
I have a Samsung fridge.
Hi and welcome to FixYa, I am Kelly. The best temp is 0 deg F or -17 C Frozen foods keep best at this temperature. You can operate it up to 10 F to save energy. Anything higher than 10 F and the ice maker will stop working. A good rule of thumb for freezer temps is to watch the softness of ice-cream. If it is too soft it is too warm. The ice cream container should be firm and not squeezable / spongy.
Thanks for choosing FixYa,
Kelly
Samsung gas oven 6 months old. Oven light flickering and clicking sound
Clicking or cracking
While oven is in use: These sounds are the circuit relays switching. ... You can try to remove the moisture by heating the cooktop (or oven), or by unplugging the cooktop and letting it dry for a couple hours or overnight.
https://www.samsung.com/us/support/troubleshooting/TSG01110180/
