Hi, since you know where the resistor is, that is a good place to troubleshoot the system. The problem is probably the switch but may also be the motor. You will need a 12 volts test light to troubleshoot. You can get a test light for less than $10 if you don't have one.
First, pull the connector off the resistor and connect your test light clip to a good ground point (bare metal spot on the frame of the dash.
Verify the relay and fuse are good by turning the key and switch on and probing the dark blue wire at the resistor connector terminal. If there is no power there, the problem is the fuse or relay in the box under the hood.
If power is there, next check the switch by moving your test light clip to the terminal of the dark blue wire (key and switch still on, so you have battery voltage on the wire).
With the switch set to "1", probe the dark blue wire with the brown stripe. If there is no light the switch is probably bad. Check a few of the settings. For example, with the switch on "2", you should get a light by probing the dark blue wire with the orange stripe. On setting "5", you should get a light on the dark blue wire with a green stripe.
If the switch is working, the blower motor is probably bad.
If the switch is not working, check the ground connection to the switch.
Please let me know if you have questions, and thanks for using FixYa.
Check if the blower is getting power 12 VOLTS,and GROUND if it is, then the blower is bad. turn it on and rap on it with a hammer, if it starts to work its BAD.
