First question: Are you using a flash? If so, you MUST be sure that your camera is set to the proper shutter sync speed, usually 1/125, sometimes 1/60, sometimes higher or lower. It'll usually either be marked on the speed dial with a red X, or the numbers will be in red, or there'll be an X next to the numbers. Using a speed higher than that speed, the flash fire part way through the exposure and cause the half cutoff you're seeing.
You can however, use any speed BELOW that speed safely.
If you're NOT using a flash, any speed is OK. But, if you're still getting cut in half frames, you're experiencing a shutter issue and need to consult a repair tech. You can find one locally if you live in an area lucky enough to have one, contact Canon for a center, or contact KEH Camera in Atlanta, GA through their website or 800-number.
