Try to check this link it has a schematic diagram of your IC.http://www.alldatasheet.com/datasheet-pdf/pdf/108380/ALLEGRO/STRF6626.html hope this may help you good day and best regards.
thanks, I've checkd it's voltages and are way diferents as sony manual shows.
I found transistor Q502 in short, I check the fly back and it works properly, do you have another extra recommendation on this?
Sir can you give me the part number of the transistor.
2SC5426-01 H-OUT, it was full in short, I just replaced it but i'm waiting for your advise, in order to prevent risks or damage to the same transistor, thanks a lot.
Try to check the driver transistor beside the H-OUT and the diode if this part are ok you can replace it.
Driver transistor is ok, diode? what diode? diode 520 & 521? they are ok....
thanks again.
You can now put your new horizontal transistor. But when you test the unit you should check the heat sink if the heat is normal but turn it off when touching the heat sink of the H-OUT.
how do you recommend the test?
with crt connected? or could be with out it?
thanks
Sorry for the late reply, you can now test it with the crt but only for a seconds then try to feel the heat sink of the H-OUT if producing to much heat. Let me know what is your observation thank's.
thanks, Heat sink is cold, unit worked well for a few seconds, with audio and video, but now, it just turns on, there are video and audio and after 2 or 3 seconds, goes off, led blinks 4 times...
thanks...
Is the H-OUT is shorted again?
no, it's ok
If you unplug the unit and plug it, does the unit power on, do you have schematic diagram?
the unit doesn't power on if so, but if press power on button goes on, and after few seconds go off, and now there are 5 blinks, I have diagram.
Can you check the voltage while the tv is plug in the ac outlet. we should do some voltage checking. Let me know if you can, because it is dangerous if you are not familiar with the test point.
yes, I can, but now led flashes 4 times...
There is a problem with str regulator it has a over voltage protection, or check your B+ if normal. When you replace the H-OUT did you replace the str regulator.
Sir replace the str regulator it is damage when the H-OUT is shorted.
I didn'n, but I'll do it, B+ is 135, but unit shuts down... I'll replace STR, thanks a lot... I'll inform you results.
Serial number model kv-32xbr48 ic 601
