2001 Dodge Caravan Logo
Anonymous Posted on Jul 26, 2011
Ive reset codes by unhookin negative battery cable, then came back and reset again and codes p1684 and p0700 came up, do I need to have tcm reset at dealer again.... transmission still in limp and cheack engine lite still on w/ those codes.... I did change transmission shift silonode. can you tell me what I need to do...
gerd butler
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jul 26, 2011
gerd butler
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
12789
Points
57
You will have to go to the dealer to reset the codes
3answers
2001dodge minne van v6 code 1684&0700 trans starts off in sec &wont shift/
code p 0700 refers to transmission control module(TCM)--malfunction===causes ---wiring---TCM
check for loose / corroded wiring connections and or/ replace thet TCM
Transmission down shifting to 2 code po 700 or but it does not shift to 3rd gear anymore was resetting it 1st time lasted a month then every 2 or 3 weeks now i can"t reset it anymore no codes
P0700 Transmission Control System Malfunction OBD-II Trouble Code Technical Description Article by Dale Toalston ASE Certified Technician Transmission Control System TCS Malfunction What does that mean? Many vehicles have a control module for the automatic transmission called a transmission control module (TCM). The engine control module (ECM) communicates with the TCM to monitor the automatic transmission for faults. If the TCM detects a fault in the automatic transmission and sets a transmission related fault code, the ECM is informed of this also and sets a P0700 in the ECM memory. This illuminates the Malfunction Indicator Lamp (MIL) to let the driver know there is a problem. If this code is present and the MIL (Malfunction Indicator Lamp) is illuminated that basically means there is at least one transmission code set in the TCM's memory. P0700 is an informational code only. It doesn't point to a direct fault in the engine, only a general fault in the transmission. More diagnosis is necessary to identify what the transmission fault is. This requires a scan tool that will communicate with the transmission module. Symptoms Symptoms of a P0700 DTC may include: Malfunction Indicator Lamp (MIL) illumination The transmission may exhibit drivability problems like slipping, etc. Causes More often then not, the cause of this code is that there is a transmission problem of some kind. The TCM detected the problem and set a code. P0700 means that a fault code is stored in the TCM. However this doesn't rule out the possibility of a failed PCM or TCM (unlikely). Possible Solutions For a P0700 the only real solution is to acquire a scan tool that will communicate with the transmission control module. Extracting this code from the TCM will be the first step in repairing the fault in the transmission. If the TCM compatible scan tool will not communicate with the Transmission Control Module then that is a good indication that there may be a fault with the TCM itself. Register now to ask a question (free) Related P0700 DTC Discussions pt cruiser P0605, P0700, and P1391 What does P0605, P0700, and P1391 mean....I just put in a new catalyst on my car for smog but light engine turned back on...and I can't seem to know what is wrong ...please help me out here... 2002 Dodge Intrepid P0700 & P0841 code my code scanner come up with the codes PO700 and PO841. the 700 code i was told it was the input and output sensors.i had those changed a month and a haft a go. now they are back on and the po841 is on were is the 841 sensor located the machanic i go to tells me my transmission has to be replaced bu... ODB Codes Dodge Caravan 2005 P0700 and P0522 Hello I have a 2005 Dodge caravan and need a fix for these codes please.. P0700 and P0522 came up.. basically ths is stuck in limp mode or 2nd gear.. I am thinking I need a new Transmission Control module.. but can anyone confirm that... 2001 Honda Civic accord p0700 and p0740 Hi I went to get my Honda civic check and p0700 and p0740 codes came up the car has a lil leak But however the car is not slipping or anything. it's not showing no Transmission sign issues. I wanted to know what could possibly be the problem thanks you... 2005 Dodge Caravan P0700 and P0420 I have a 2005 Dodge Grand Caravan.The other day the check engine light came on.I stopped at auto parts store and they checked codes for me.P0700 and P0420 are the codes that came up.What do these mean and why did they show up?My van is running fine.Do I need a tuneup?Or is it something else?I am hop...
Read more at: http://www.obd-codes.com/p0700
Copyright © OBD-Codes.com
4helpful
2answers
What do the codes P1684 and P0700 mean?
Hi Rich Stuck,P0700 means Transmission Control System (MIL Request),P1684 means Battery Disconnected within last 50 starts.More read Diagnostic Trouble Code Table ,hope it can help you.
1helpful
What is the code p1684 and p700
The P1684 code means simply that the battery has been disconnected within the last 50 starts, You can effectively disregard this unless you know that to be false. Then it could be an indication of an impending battery failure.The P0700 code is more troublesome. I collected this information from another source:
  • Malfunction Indicator Lamp (MIL) illumination
  • The transmission may exhibit drivability problems like slipping, etc.
Hope this helps!
1helpful
P0700 code on my 2003 kia sorrento. I HAD THE THROTTLE POSITION SENSOR DONE, EVAP EMMISSIONS LEAK DONE, TUNE UP(NEW PLUGS) NOW WHAT? THANKS!
p0700 is a trans code its from the tcm it sends a message to the computer saying that you have a transmission problem and a sensor that is connected to trans is causing a code for example the tps is connected to trans for shift and rpm so it is possible it kept it in memory you need a scanner which can go in to the tcm and check the code if worst unplug battery lets it reset for 15 mins and retry if it lights up again you need to check the code from tcm
8helpful
3answers
Car does not run ,I check the code ,it is P0700
Because it is not starting, you should replace the Crankshaft sensor (above the oil filter, back of the engine)-it will cause a P0700-I have a 99 SL2, 178,000 miles
DTC) CODE # P0700....Transmission Control System (MIL Request)
Translation: Transmission Control Module (TCM) Malfunction or Failure. P0700 Information Code The Transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM. This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it. The dealer probably saw the code P0700 and went to the TCM and pulled out the code stored there telling them the Transmission Solenoid Assembly (TSA) is bad. This is a good example of understanding what the codes actually mean. If the manual you looked at said the TCM is bad and to replace the TCM when you see a P0700, then it is wrong.
5helpful
2answers
I got two odometor codes p1684 and p0700 do you know what it means 2002 chysler town and country
P0 700 is a transmission control malfunction and P1684 is a indication that your battery was disconnected within the last fifty states.However what is puzzling is your PO 700 is a generic code your P1684 is a dedicated Chrysler code your cars computer should only store one or the other not both.
5helpful
Camshaft Position Sensor
P0340 Camshaft Position Sensor "A" Circuit Bank 1 or Single Sensor
P0700 Transmission Control System (MIL Request)
The code P1684 is real easy. The computer is stating that the battery has been disconnected within the last 50 starts.
2answers
I have a diagnostic code of p0700 and p1684 coming up for my 2002 dodge neon...anyone know what that means??
Hey, Code 0700-Transmission Control System (Malfunction Indicator Light Request)
Code 1684 -Battery disconnected during last 50 starts
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
