My Vinotemp VT-60 was working just fine last week until it started running very cold (got down to 24 degrees!). The condenser won't shut off. Seems like a thermostat problem. This happened right when I got it, but unplugging it for a few hours fixed it. This time that didn't work. Any ideas?
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
