is your hard-drive the boot-drive, if not, change boot order by pressing F8 or F12 just after hitting the start button, and choose the hard-drive that has the C:\windows on it.
or hit F11 and access hidden recovery partition with HP pavilion How to Access the Hidden Recovery Partition in HP Pavilion
With f8 or f9 you will get into the bootmenu it can also be esc f2 or f12, when in the bootmenu sellect dvd player then it will start from dvd it will give a line, do you want to start from dvd hit any key.
Hop that helped!
Cheers
While the computer is initially booting up, press F8 (repeatedly if necessary), you should be presented with a selection screen to boot into safe mode (various levels such as with or without networking) or to boot normally. The F8 key only works while the computer is going through the BIOS startup procedure.
Unistalled the USB Generic Root Hub Drivers from the Device Manager by right clicking on the generic root hubs and then restart the notebook and This will fix this issue for you....:)
If you are facing this issue while installing Windows, Most probably there is an issue with the memory card. If you have two memory modules try to use one of the memory modules in each slot at a time. If you have only one memory stick then try to use it one by one on each slot. If you it does not work then probably you might have to replace the memory stick.
You can order a power cable online or pick one up at your local computer store. They should run between $80-150. The battery itself is very expensive to purchase but is rechargeable.
install the pci,connect the monitor to it then tap f8 while booting and see if the boot option come up if they do choose vga mode and go into the device manager and disable the onboard and for more contact..http://tinyurl.com/m7ghqz
Run diagnostics on the hard drive (Normally provided either in the F8 or F12 boot menus) and se if you get a failure.
If the drive passes diagnostics, boot to the Vista DVD and run the repair option. (Note: you may have to the Vista repair process 4 or 5 times if there are multiple errors to be resolved)
