1994 Nissan Altima Logo
Anonymous Posted on Jul 20, 2011
My car was running, then died, & won't start now. It sounds like it's gonna start but never does. I've replaced the distributor cap, roter, ignition coil, & coil wire. Still no luck.
Anonymous
Level 3:
Genius:
  • Master 1,016 Answers
  • Posted on Jul 20, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1016
Questions
0
Helped
413502
Points
3013
You need to have the cam angle and crankshaft position sensors checked. These are 2 parts which enable the ignition system to fire. If these are ok then check that the rotor in the distributor is turning when you crank the engine.
If it is not turning then you have a cambelt/chain or gear problem which you will need to repair before it will start again.
Hope this helped.
Thanks
Jason
Mark Harnett
Level 2:
New Friend:
  • Expert 115 Answers
Mark Harnett
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
25860
Points
370
Any chance it was the timing belt that let go or crank sensor?
1helpful
2answers
1992 Dodge Stealth SOHC - no problems, running great, then I replaced the distributor (forgot to mark it) & now the car won't start up. It'll turn over, even got it to start once but won't...
put number 1 cylinder at top dead center and drop in distributor so the rotor points to number 1 on cap. may have to try several times as gear moves when lowering dist.
1helpful
I have a 1989 toyota celica and it won't cold
Replace the cold start injector, it is a common issue.
2003 Dodge Durango (5.9L V8) won't stay running unless you keep your foot on the gas.
Check temp sensor and TPS, throttle positioning sensor.The power control module,"pcm.is a possible thought.Just check all connections. It is always a good idea to spray WD 40 or equivalent in the connections.
Sometimes my bravada will just die while driving
check the distributor cap, it may be cracked or have a bad wire.
1helpful
Oil in the distributor cap and the dies and won't start after it dies
Oil contaminated distributor is affecting the spark,your solution is a replacement of the distributor,it basically affecting the the distributor pick up,3_28_2012_8_51_27_pm.jpg
Lately, whenever it rains, my 1998 chevy blazer wont start/won't run. the engine turns over, but it won't run. after 2 or 3 days it will fire up like nothing was wrong with it to begin with. any...
Whenever I had this problem, it was always cured with a new set of GOOD spark plug wires. Not generic set off the parts store shelf. Get some moisture removal spray and put it on both ends, the coil and the plug, before putting the wires on. Do one wire at a time so you do not get them mixed up. I do not think you have a distributor or a cap. If you do replace it also as it is over 20 years old.
96 blazer won't start in the rain.took to several professionals that cant fix it. works fine otherwise
Sounds like it could a bad coil.But if you wait until it does start take a spray bottle of water and while running spray the distributor cap and listen for it to start missing if does replace the distributor cap if it does'nt replace coil.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
