Nokia 5200 Cellular Phone Logo
A
Anonymous Posted on Jul 13, 2011
My nokia model is 5200..i want to send some picture on my gf using gprs or mms..yet every time i try .. its not working..i dont know how to fix my configuration setting please help me.. -jay
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
553
Points
9
Restore your fone and try again
It's on my Smart No. 09199634778. It received messages from Smart that I have MMS pictures. Can they be shown here?
Yes sir,to retrieve MMS data,you should activate you MMS/GPRS by configuring the settings of your network provider or Smart provider.
Here's how to Activate the your MMS/GPRS
Key in SET MMS and send to 211.
To download SMART GPRS phone settings:
Key in SET GPRS and send to 211.
Example: If you have a Nokia 6230, that's "SET MMS N6230"
To activate SMART GPRS:
Key in "GPRS ON" and send to "333′
To activate SMART MMS:
Key in "MMS ON" and send to "333′
Note :
The configuration settings will be sent to your phone. You will need to select "Save All" to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
Hope this solution helps you. Thank you for visiting FixYa..
How to open my mms and gprs coz i want to recieve and sent picture and vedeos please help me how coz i dont know what im going to do
You must work together with your service provider to make your phone enabling use MMS and GPRS. So please contact your service provider to make setting on your phone. It will required, username, password, proxy etc. To send MMS, just find the file you want to send then go to option then send. It is easy.
Regards,
Hou to use MMS
Please call customer care of the service prover line you are using and request for the manual settings of MMS and GPRS or request to send the same settings in your phone and save it. Please note that tell your phone model no to the CC executive before save the settings. Now you will be able to send the MMS.
2helpful
How to open Globe gprs to Nokia 6303
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Internet Settings
6. Create New Profile
Connect Using: MyGlobe GPRS
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
Address: http://www.globe.com.ph/globe.asp
12. Save Changes
MyGlobe Internet Settings
3. Create New Account. GPRS / PS Data
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
1. Go to Menu>Choose Settings>Connectivity
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
Connect Using: MyGlobe Stream
I qam having nokia 5233, i have GPRS from BSNL
get the mms settings first which is provided seprately by bsnl network, call customer care to know the procedure to get settings
1helpful
Displaying that "CAN NOT ADD NEW ACCOUNT,MEMORY FULL "
Check this site. This is my blog where i have posted the solution for this error. I found it for my nokia 6085 and worked well. Check it: http://inxis.blogspot.com/2009/11/gprs-mms-settings-error-nokia-solved.html
My 3110 wont let me send pictures
hi there,
you can follow the procedure inserted below hope it will help you to solved your problem...
any further question you can log on this site,,
http://www.yugatech.com/ringtones/tips-tricks/activating-your-smart-mms-gprs/
Here’s a quick tip on how to activate your phone’s Smart MMS and Smart GPRS settings if you’re with the Smart network:
Download MMS and GPRS settings from Smart:
To download SMART MMS phone settings:
Example: If you have a Nokia 6230, that’s “SET MMS N6230
Key in “GPRS ON” and send to “333′
Key in “MMS ON” and send to “333′
Note :
The configuration settings will be sent to your phone. You will need to select “Save All” to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
8helpful
9answers
GPRS
i dont konow how to open my gprs
6helpful
4answers
I dont know how to set up my phones MMS and GPRS.
YakYak, Go onto your network providers website register on there, and there should be a option once you have signed up, confirmed your email address etc... You should Be able to set it up for MMS & GPRS, hope this works and good luck.
Ben
2answers
W810i model
check your gprs and mms settings,contact your network operator for help
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
