GE 20.3 cu. ft. / 575 liter Upright Freezer FUF20DPRWH Logo
Posted on Jul 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the normal temperature setting for a ge upright freezer, dial from 6 to off?
Charles T Nevin
Level 3:
  • Master 4,070 Answers
  • Posted on Jul 10, 2011
Charles T Nevin
Master
Level 3:
Answers
4070
Questions
0
Helped
1088225
Points
13055
Your need to use a thermometer and adjust the dial till you have between 0 and 10 degrees.
Need mamual model FFU11FKODWO upright Freezer
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
My GE FUF14SVRWW upright freezer will shut off for no reason. The digital temperature control will be blank, the light will not turn on, and freezer isn't running. I will unplug it for a few minutes and...
Ach, digital controls! It sounds like the logic board/panel is on the fritz. No cure unless you can identify the malfunctioning component and replace it.
What temperature shoud it be on please - it has from 1 to 3
I would suggest setting it on 2. But to eliminate guessing, the dial should be set so the temperature in the freezer compartment is 0 degrees F (-18 C). The best way to ***** this is to put a thermometer in the freezer and adjust the dial until the temperature is steady at 0.
Charlie
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
11helpful
2answers
Freezer temperature swings
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
Jun 24, 2017 • GE Freezers
1helpful
2answers
Freezer cycling on and off rapidly
If it still maintaining temperature but is short cycling your control for the temperature is wearing out causing the short cycling. This is a replaceable part that can be obtained through a dealer or appliance parts supplier. By lower setting do you mean lower number on the control, or lower temperature setting? Normally the higher the number the colder the temperature.
May 14, 2008 • Freezers
Top GE Freezers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
