Is there a reset button on the freezer anywhere? I cleaned the back grill on my old freezer and it...
(More)
Is there a reset button on the freezer anywhere? I cleaned the back grill on my old freezer and it quit running. All I did was vacuum it. Also, the light quit burning at the same time.
I bought a used chest freezer. Its 4 foot long, 3 feet tall and 2 feet wide. I plugged it in over...
(More)
I bought a used chest freezer. Its 4 foot long, 3 feet tall and 2 feet wide. I plugged it in over night and checked it in the morning and it still was not cold. There was nothing in it over night, could that be the problem? It is on the coldest setting being setting "7". I can not hear it running, but the light on the front of the freezer is on, so it must be on, how do I check it to see what is wrong with it? Thank you, Alissa
Freezer motor runs, but doesn't cool down and freeze. I'm afraid it might be the cooling unit, Is...
(More)
Freezer motor runs, but doesn't cool down and freeze. I'm afraid it might be the cooling unit, Is this an expensive fix, and would it be better to just get a new freezer?
Very Old Hotpoint standup freezer will not stop running, is it the thermostat? I have defrosted it...
(More)
Very Old Hotpoint standup freezer will not stop running, is it the thermostat? I have defrosted it manually (opened the door and took the back panel off to expose the fins and let completely dry) Still runs at the lowest setting. I can turn it off with the setting knob.
bottom gets real cold but top stays warm 40 to 45 I have the same problem with my magtag upright...
(More)
bottom gets real cold but top stays warm 40 to 45 I have the same problem with my magtag upright freezer. It's two years old. It gets about 40 degrees about will not freeze. Any thoughts?
Defrost your freezer quickly!
Steps
1. Turn the freezer off (unplug it).
2. Take out all the food.
3. If required, unscrew the inside-back of the...
by wikihow
Most refrigerators come with an automatic ice cube maker. Many of the younger generation, have never seen, or heard of making ice cubes any other way....
by wikihow
