How do you remove the front cover? Where can i find the instructions?
To remove the front cover you need to start by putting the monitor down flat on its face on something that wont scratch the screen.
Next, remove the screws holding the base to the back of the monitor. (You might need to remove a plastic cover to get to the screws).
Once you have done this check for a screw under where the base was screwed on. Remove this screw.
Now check the back of the monitor for one screw in each corner. Not all models have these 4 screws,if they are there, remove them.
Now the front and back of the monitor are held together with plastic clips. You will need to gently pry the front and back apart.
Its easiest starting at the bottom middle and working around.
Once you have separated the front and back, the inner circuitry is exposed. The control panel for the unit can be removed by unscrewing 3 screws that hold it in.
