Section 01-09: Mirrors, Rear View
1999 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 06/25/1998
Mirror, Power-Outside Rear View
Removal
Item
Part Number
Description
Outside Rear View Mirror
N621906-S36
Nut (3 Req'd)
F8DB-17D699-
AAW
Cover Assembly Rear Substrate-LH
F8DB-17D698-
AAW
Cover Assembly Rear Substrate-RH
N808968
Screw
5
F8DB-18B984-
AAW
Speaker Grille-Standard (No Badge)-LH
5
F8DB-18985-
AAW
Speaker Grille-Standard (No Badge)-RH
5
F8DB-18K901-
BAW
Speaker Grille-Mach-LH
5
F8DB-18978-
BAW
Speaker Grille-Mach-RH
5
F8DB-238A35-
AAW
Speaker Grille-Blank (No Speaker)-LH
5
F8DB-238A34-
AAW
Speaker Grille-Blank (No Speaker)-RH
A
Tighten to 6-8 Nm (54-70 lb-in)
Trim Panel, Door
Front
Removal
Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
Installation
Front Door Trim Panel
Lamp Assembly - Taurus Sedan
Removal
Open luggage compartment door . Remove quarter trim panel. Refer to Section 01-05.
Remove three nuts from rear lamp mounting studs.
Pull rear lamp away from vehicle.
Lift tabs on turn signal lamp connectors and pull connectors away from parking lamp socket and wiring .
Installation
Follow removal procedure in reverse order.
Tighten nuts to 5-7 Nm (45-61 lb-in).
