I have a Philips LCD 220CW monitor that has a vertical line 'scanning' back and forth. On the bottom left it says Smartimage ON and on the bottom right it says Smartimage off. How do I make this stop?
Just hold the smart image button (last on left side of display)
I had same problem a second ago, so it worked for me.
Posted on Jun 17, 2011
thank you very much!
thank you
Valeu!! Achei que ia ter que jogar o monitor fora!!..kkkk
thank you!
thank you!
Thanks Core... you saved me there :D
Thank you. You saved me from going crazy at my monitor.
Thanks a lot dude...you saved my life.
thank u very much dude....
thank you
Obrigado!!!
when it 1st time appear it worked, but now i'm having same problem and this time it's not working
Thanks so much but i didnt know you had to take so long to hold the button XD
Thanks, it was helpful. For the first time it worked for me. I hope there won't be the next time :)
Aiuto! non funziona. Il "tasto" smartmage off oppure on, non sono cliccabili con il mouse ne con tastiera. Come posso fare per eliminare la riga bianca?
gracias!!! gran ayuda!!! funciona perfectamente!!!
muito obrigado pela dica
Thank you very much
Have a Philips LCD 220CW monitor that has a vertical line 'scanning' back and forth. On the bottom left it says Smartimage ON and on the bottom right it says Smartimage off. How do I make this stop?
Posted on Oct 08, 2010
Push the first button (begining from de bottom) five seconds and the option smartimage set to off.
HOORAY i FIXED IT CHAMPS THANK YOU
thanx dude it really worked
worked
done
if it wort but my monitor doesnot work
Non riesco a toglierlo
if the menu button spoil, have you other matter to solve it
Hello, I have a monitor LCD Philips 190 C8 - trhe trouble is one vertical line sanning left and right ; at the bottom of the image there is mentioned Left: smartimage on ; Right ; Smart image OFF . How can I settle this?
Thank you!
Posted on Jul 01, 2011
hold down the menu button (first on the left) on the screen for about 30sec....that should turn off the smartimage.
it has no effect on my computer
where can I find the smart image on my computer,help me plz
Press smart image off button
Posted on Apr 14, 2010
where is the Smart Image Off button please?
hi there... how to get the option to stop the vertical line? what key i need to press? please.. help...
thank u so much man
hi...tried your solution but it didn't work...could you be more specific which button should be pressed for 5 seconds? thanks!
hellow sir my pc have smart image and its scanning how to stop it???
tanx guys dat worked for my 19 inch lcd as well
hi..ammmm i have the same problem too..but mine is worst...my monitor's control are lock...how do i unlock it...?
cual es el boton inteligente,si esel de apagar windows no funciona ese metodo
press and hold the left hand button (smartimage button) for 20 seconds. this will unlock the controls and turn off the smart image demo.
Wow what a horrible design. wasting time of its customers. I am surprised anyone would want to purchase one of these ever again.
OK i have the same problem but with a Philips smartimage 20'' screen. Need better info about this first button.
1) where is this button? (on the key board or the touch buttons on the screen)
Thanks HERC
Posted on Jul 06, 2011
here you can find the location of buttons:https://www.protectpages.com/blog/exitfi...
I tried and hold SmartImage on for 5 seconds, but nothing changes ...
Posted on Jul 12, 2012
I had the same problem with my screen. left button on screen worked to stop it.
it seems as if this kind of screen is very sensitiv on cellphone waves.
if my nokia is close to the screen the screen starts to setup different things for itself.
Posted on Apr 24, 2013
Tanks, It work
Posted on May 16, 2012
VERRY NICE GOOD WORK THANKS BRO... HOLD 10 SECOND FIRST LEFT BUTTON WORK 100%
Posted on May 06, 2015
thanks a lot. I would also like to share that if you have the message monitor controls locked message on the screen then you need to connect the pc and keep the right most button pressed for about 10 seconds.
Press Arrow Button 5 Sec.
ho lo stesso problema ma che non risolvo con il pulsante freccia. Cosa posso fare?
Quale pulsante freccia quello sotto F11 F12 ?
ho premuto tutti i tasti freccia sulla tastiera ma non si toglier la riga bianca smartimage :((
