it probably needs a air hammer addition. you could buy one or make one buy adding a inline "T" a short piece of pipe and a cap. which help balance pressure.
if its valve chatter you will hear it just under the valve cover pretty pronounced, but usually valve chatter gets quieter as the bike warms up, you might look into your cam chain adjuster those get loud and chatty at higher rpms.
ok are your drivers for your sound card updated ? does the derict x show any error when you run the analytical scanning of your system? have you ran any chatt web page sound and cam testing at the chatt site your seeking to play music at?( Yahoo and MSN both have thier own sound and cam tests for thier chatters Hope this Helps Steve
i did not watch your video,however chatter noise on start up means lack of lube and cam end play so check for oil clearence between cam and bearing valve clearence
Very important. When tentioners, (primary & secondary cam chain tentioners) where replaced. Did they update bearing support plate bearings, and even more IMPORTANTLY.
INA Inner Cam Bearings removed and replaced with Torringtons?
If not you are about to experiance a broken oil pump body, feed & return gears for pump. And either new cases (3,500 bucs) Or repair, which I'm unsure of cost. Haven't gotton bill yet. Wish I could add pics.Unbeleavable what needle bearings can do to. Waiting for cases to come back... Customer took this as his opportunity to custom build A MONSTER of a motor.
When INA bearings are chattered they do make a whirring noise.
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas?
replace relay as it is easily available or make it direct.
