Dear rkgoyal24,
your restarting problem may cause because of overheating when you play video files.please clean your hardware components inside your CPU cabinet and make sure that your CPU fan is working
Thanks for your Posting.
Media/ Gaming
etc consumes more CPU/ Processor resources and due to the heavy processing
the PC heats up. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Heating issue generally occurs due to fan
failure, which may damage the system, if not checked properly. Another
most likely cause of overheating is the dust present inside the PC, which clogs
the fan and heatsink.
1. Make sure the fan is running. (if not, it needs replacement)
2. Clean the fan and heat sink (thermal module). Take out the fan and heat sink. clean
them with the help of tooth brush and put it back.
3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The
procedure is very simple and I believe immediate
action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
