1998 Ducati Monster 900 Logo
A
Anonymous Posted on Jun 29, 2011
Tried to start my 1998 monster 900, turned for a while until battery went flat. Put battery on charge, and tried to start bike next day. Starter wouldn't turn at all. Any ideas?
gavin jones
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Ducati Master 1,508 Answers
  • Posted on Jul 01, 2011
gavin jones
Ducati Master
Level 3:
Renaissance:
Answers
1508
Questions
0
Helped
484556
Points
3349
May need to try a new battery, they somtimes stuff up in less than 12 months especially if the bike sits
  • 1 more comment
  • leon
    leon Oct 24, 2017
    looks like you need a new regulator, if your bike was running and it drain the battery insted of charging it its the regulator .
  • leon
    leon Oct 24, 2017
    good luck
  • Gavin Jones Oct 24, 2017
    Leon you do realise he may have sorted this out 6 years ago, and its not an alternator issue, the bike wasn't running and charging the battery didn't help
1helpful
Starter will engage but motor will not turn over
follow each step in the torubleshooter until you find the trouble.
2answers
Put in new battery still no power. was riding and everything went dead. the bike is a 98 cbr 1100
Hi and welcome to the site,
Initially, have you checked the 30A main fuse? It would be inside the starter relay. To locate the starter relay, follow the cable from the battery's + terminal.
Good luck and thank you for asking.
2helpful
Ducati 900 Monster starter issue
Have battery load tested, check all connections on starter, on battery, and on the engine where the ground cable hooks up.
Charged battery up for bike because would not start
?.....was the bang when you tried to start the bike...or as you turned ignition on?...if when you turned ignition on sounds like you need to check wireing...if bang was when you truned eneing over it could be unburt petrol that banged when bike tried to fire up !!...
Starter issues
try tapping on the starter motor/solenoid, it sounds like the solenoind is engaging(the clunk you hear) but the starter is not turning if the wire is getting hot it could be the starter is frozen up.
Starter and possible wiring issues with custom bike
Did you try removing the starter and testing it on a "bench"? Sounds like it might be "jammin" up. Loose, misalignment, it's worth a try and doesn't cost anything. good luck
3helpful
Harley davidson evo motor wont turn over...just clicks
Pull the spark plugs out and hit the starter. This will make sure that the engine is not locked up. If the starter does not turn the engine, put the bike in first gear and have someone push you, making sure the engine is free. If the engine is OK, your starter is probably jammed and needs replaced. That wire getting hot is a dead giveaway something is locked up tight...starter or engine. If ya have a large hi-performance engine in the bike, chances are your stock starter won't do the job.
Top Ducati Experts
Arnie Burke
Arnie Burke
john h
Are you a Ducati Expert? Answer questions, earn points and help others
