Dry = Replace
Wet = Not replace.
Hi edchen111,
You seem to be quite familiar with your system, and you are right on track when you say that you should try and replace the thermal paste , because many a times it's the only reason that we find computer freezing up randomly and frustrating us.
Also clean your RAM with an eraser , i mean the connectors of RAM which go in the slot.
Try changing the RAM slot as well and then you won't have such problems of freezing , provided that your hard disk is without viruses and operating system is not corrupted.
Hope this helps ..:)
LOL. Didn't need to replace the paste. Found out the problem, and it wasn't my fault either. Turns out gateway had a lawsuit over this model because they were too cheap to put exhaust and intake fans into it, causing it to randomly shut down. Went to best buy, bought 2 Antec fans, problem solved.
That sounds Good Congratulations !
