If you are referring to the Jumbo Remote, the codes can be found on the website at http://www.jumboremotecontrol.com/remote_control_code_list.html.
To program the remote, use the following steps:
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Here are the codes that they list as being potentially applicable to your television:
003,051,055,062,070,148,170,171
SOURCE: Code for innovage jumbo remote.
try this website, i specifically found the Innovage jumbo remote codes here, but if you scroll down it has several remote codes listed by manufacturer of the remote. Hope it helps!!
http://www.xdiv.com/remotes/
SOURCE: Codes to program Innovage Products Jumbo Universtal Remote
H have the jumbo universal remote from innovage pruducts. can you e-mail me all the codes? thanj you. [email protected]
Innovage Jumbo remote codes for RCA TV; 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191,194.
Pansonic DVD; 175.
Pansonic VCR; 021, 060, 115, 125, 138, 148, 149.
Philips DVD; 173, 183, 198.
Bell ExpressVu; 168, 187, 194.
SOURCE: living solutions jumbo remote codes for a sony tv.
The codes are ,002,006,071,128....hope this was helpful..
SOURCE: i need codes for a panasonic tv for a tde systems
the codes for panasonic tv are 0718.0416.0007.0618.0807.0039.0739.0345.0696.0901.0608.hope this helps.
