Manufacturers say to replace water heater after a flood.
Flooded water heater can be repaired by replacing parts but warranty is voided.
And if water heater reached gas control valve, then gas control has to be replaced >> possibly the gas valve eco tripped.
I don't know how effective cleaning burner parts will be, since a small spider wed inside some of those tubes can cause water heater not to function. Small obstructions cause big problems.
I'm sure the plumber cleaned it out real well.
Find manufacturer using label on side of tank, find manual with parts diagram, and order burner parts.
http://waterheatertimer.org/Water-heater-manufacturers.htmlIt might be cheaper to install a new water heater yourself from box store
http://waterheatertimer.org/How-to-install-gas-water-heater.htmlI read one article:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/Guy has water heater that filled with water.
He says: "I decided to feel around. As soon as I put my finger into the hole under the burners I hit water. The air intake passage was filled with rain water, effectively chocking
off the fresh air. A few minutes with a siphon tube cured the problem
and the water heater works normally again."
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
