SOURCE: motor hums then clicks off
Has the motor seemed a little slower in starting than usual? If so then you probably have a weak or defective motor capacitor. Try switching out with a new one.They are inexpensive.Try to turn the motor shaft at rear (under end cap) while it attempts to start. If the motor kicks on then replace capacitor.
SOURCE: Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
SOURCE: pool pump
check to be sure that the motor wireing is the same as the wireing going to it 115or230 most motors can be converted look on motor for wire diagram.
SOURCE: pool pump is not working
The motor capacitor is bad. This usually means the motor is shot. It's hard to get capacitors for a quick fix
SOURCE: how to install motor housing bracket on a jacuzzi
The 'toothed' edge goes on top with the teeth facing towards the motor. You will also notice the small support arm in the plastic is narrower than in the other areas of the bracket. That lines up with the seal plates locating tabs so everything is then lined up correctly for the insertion into the housing.
