The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Has your modem been hard reset recently? if so, it may require that you bridge the modem out to work with the router- ESP. if you use Verizon DSL. If so, contact your ISP, and ask for assistance in bridging out the modem.
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
If your computer is able to go online through the modem Then you need to connect the computer to the router ad the modem to the router. open the set up page of the router and change the settings of the router according to the ISP. Click Here for step by step by instructions
Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
If could be that you were unable to reset the router properly. You have to make sure that the router is on while pressing and holding the reset button using a paper clip. the reset button is usually found at the back of the router, then you may have to reconfigure the settings again.
you can also manually access the router page for you to change the settings.
Try to do a complete power cycle on your devices. Turn off router, turn off modem, turn off computer. Wait for 30 seconds then turn on modem first, wait for all the lights to stop blinking then turn on router the reboot computer. Hope that helps
-- what is the operating system of your computer? -- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer. Step 2: reset the router while power on then Unplug the router’s power cable. Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds. Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable. Step 5: Plug in the router's power cable once the modem’s lights appear stable. Step 6: Power on the computer on Step 7: test the Internet connection on both pc
if this still didnot work, upgrade the firmware of your router
