your keyboard is not connected properly, because boot should response when you press any key, check the connections of keyboard or replace with correct one.
as far the massage concern, it shows the windows gone corrupt re-installation is recommended.
to turn off predictive text go into messages-select- create new -select-message-text message-select then press and hold the * key and you will see in the top right corner it changes from ABC to abc or T9. to send sms messages go to settings -select -application settings-select-message-text message-select-sending options-select- GSM alphabet then maximum then text.
Hope this helps.
try to reformat your phone first turn off your phone and press hold * 3 call sign and turn on your phone you must hold press those key until your phone is reformatted
i think your sticky key option on. try this,press shift key 5 times and message will appear then go to setting and uncheck all option and apply. please rate this
Press and hold the Alt+key and while doing that type 0163 using the numpad. This means on your notebook keyboard, you have to hold the Alt and Fn-key and than press the keys which contain the blue numbers. So in your case press: m j o l in this order...
Initially, have you checked/pressed on the "Scroll Lock" key (between Print Screen & Pause). To my knowledge, on most keyboards, the three common indicator lights are: Num Lock, Caps Lock and Scroll Lock.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
The half-white screen is definitely not a good sign. The "hold and tap" screen you see is the alignment screen normally seen at a "fresh" startup.
If this is the PPC6800 Mogul, there is a small pinhole reset button on the bottom of the unit. Using the stylus, push the button, This will "soft reset" the unit.
If this doesn't work, you can try hard resetting it:
1. Press and hold both softkeys on the device. (The soft keys are the buttons to the left and right of the center navigation wheel with the white dots on them) Keep these keys pressed, and at the same time, use the stylus to lightly press and hold the RESET button on the bottom of your device.
2. Release the stylus but keep the softkeys pressed when you see the following message on your device screen: “Do you want to erase all user data and restore to manufacture default?” 3. Slide open the keyboard, and press R to restore to factory default or press X to exit the hard reset process.
This may take a few tries, as it's hard to hold the buttons and push the reset button.
How do you get the & sign on the K800i when text messaging.
Kind regards
Richard
