I have a N150 plus netbook, 6 mo. old. Using it on the internet this afternoon, it froze up; went to Task Manager, which also froze. I then rebooted and it won't boot--powers up, gives the "samsung" screen, then nothing. I've done F2 and restored to original defaults; still nothing. I've also done F4 Recovery--nothing.
Now what?
You should be able to press 'F4' at boot time and access Samsung
Recovery Software, and then reinstall the back-up that would have been
made the first time the netbook was switched on - a 'factory reset'...
Insert the Windows disk into the computer. Restart the computer. Press any key as prompted to boot from the disk.2 Select your language, keyboard, and currency preferences. Click "Repair your computer."3 Select the drive containing Windows and press "Next" to detect and repair problems with the operating system. OR how to fix Microsoft Internet Explorer when it is not responding to return to surfing the web Click the "Start" menu button in
the lower-right corner of your computer screen. Click "Run" and type
"msconfig" in the search field. A dialog box will appear that lists all
software programs enabled to run when you turn on your computer. Disable
all of the programs except for essential services such as your
anti-virus software and firewall. Restart your PC.2 Hold down "Ctrl," "Alt" and
"Delete" on your keyboard simultaneously. This will activate the Windows
Task Manager. Select iexplorer.exe" in the list of running programs
and click "End Task." Continue to Step 3 if that does not close the
Internet Explorer browser.3 Click the "Start" menu button. Select "Settings," then click "Control Panel."4 Click "Add/Remove Programs."
Double-click the Microsoft Internet Explorer icon and select "Internet
Tools." Click "Repair Internet Explorer" and press "OK." Microsoft
Windows will scan your copy of Internet Explorer for errors or bugs and
fix them.5 Open "My Computer," accessible
on your PC desktop or in the "Start" menu. Right-click on your "C:
Drive" and select "De fragment Occasionally, your hard drive might
misplace program data, which results in software freezing or not
responding. Repeat the defragment process with the "D: Drive" and any
other hard drive partitions.6 Click the "Start" menu button and select "Restart" to reboot your computer and apply the changes made in Step 7 Return to browsing the web with Internet Explorer.
Check to make sure your wireless driver is functional (this is located in device manager if you are running windows 7 right click computer>properties> Device manager (located on left blue bar)
if that is working make sure that your wireless switch (located on right side of laptop) is turned on
and if that is on then make sure you have the right password for the network
WHat programs are running at that time? Please check using task manager. There must be a program that activates itself when internet is accessible and then present the abnormal behaviour. Suggest closing programs (end process from task manager) one by one while the screen flashes in order to determine the culprit.
check mo sa system device manager kung properly installed yung driver ng cam mo. if not, load mo ulit yung cam driver. if yopu are using win7, auto configure na yan sa internet right click mo lng yung not properly installed na device then select scan drivers for auto detecting and installing drivers galing sa internet.
Can i have the brand name of the modem , Your Internet service provider name , so that we can configure the router with using the CD.
We have another method to configure the router that is manual configuration method.
