Forgot Windows 7 Password,
you can remove or reset it. For removing Windows Passwords in safety, I highly
recommend windows password reset tools. Last week, and then I downloaded one and
used it to remove the lost password
successfully.
http://www.reset-windows-password.com/reset-windows-7-password.html
This sounds pretty interesting. We used a similar software at my tech support job a few years ago. Called "Windows Password Seeker". It works very prefect to regain your password. Also use boot CD/DVD.This software from: http://www.passwordseeker.com
If you forgot your windows admin password, I suggest you to remove it with windows password reset tools. I removed my windows password successfully with Windows Password Reset 9.0 yesterday. You can have a try http://www.reset-windows-password.com
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
I know a risk-free method to retrieve the password and it need no reinstalling Windows. The software program called Windows Password Seeker which has been recommended at about.com. You could Google Windows Password Seeker or download it fromhttp://www.passwordseeker.com. It can recover almost all Windows passwords in seconds. It also compatible with windows 7.
How to use the Toshiba BIOS password removal tool: connect the plug to the parallel port on your Toshiba laptop and turn on the laptop.
You should bypass the BIOS password and the laptop will boot directly to the operating system.
You can find and purchase the BIOS removal plug here.
Before you buy, make sure it works with your Toshiba laptop.
UPDATE for all Toshiba owners:
Some newer Toshiba laptops can start asking for the BIOS password even if the password has never been set. This affects the following models: Satellite A100, A105, A130, A135, A200, A205, L35, M200, M205, P100, P105, P200, P205 and probably some other models.
Before you can use the laptop, the BIOS password has to be cleared.
