Make sure you have the newest updates on your ipod touch. also I would goto the apps store and try downloading a free brower and see if they will connect if not then it has something to do with the conflicting with the modem as far as maybe too many devices connected and a ip address is overlaping causeing it to glitch out.
if you can access the store on your ipod touch then there is no reason why safari shouldn't work.
another thing you can do is.
try resetting your iPod. Nothing will be lost:
Reset iPod touch: Press and hold the On/Off Sleep/Wake button and the Home
button at the same time for at least ten seconds, until the Apple logo appears
- Next restore the iPod from backup via iTunes on your computer.
- Lastly. restore the iPod to factory defaults/new iPod since there may be corruption that is now in the backup.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
also try turning it completely off by holding the power button down and then restarting it as well
I've done that though. :/ I've already tried resetting the ipod, and also resetting network connections, but it hasn't solved anything.
I can't connect to ANYTHING requiring internet connection on my ipod, including the app store, itunes, etc,
I'm pretty sure it has something to do with the ip address or something, but I don't know what to do about it.....
I can connect to the wireless network just fine, but safari and all other applications say that it can't find the server.
You should make sure all the Laptops and PC's are set to "use DHCP" or automatically acquire an IP address. Sometimes when you put the CD in for the router it adds a static IP of 192.168.1.1 and it stays there. ALL you need is automatic configure and let the dhcp in the router dish out IP addresses. IT doesnt give out duplicates. Thats where you need to start looking
I'm trying to do that (by clicking the wireless network connection, going to properties, and then to Internet Protocol version 4, TC/IPv4 and then clicking on 'obtain an IP address automatically' for both options), but when I X out of those things, and then click on them again, it goes back to the way it was before - ( i.e. 'use the following IP address....blah blah, for both sections) It doesn't SAVE the changes I made to it.
and the internet still doesn't work on the ipod.
Thanks for trying to help though.
