Possible solution to your problem is to rechecked again the connections if it is in right connection or it possible to be loosen so you better to tighten the connector from your pc,may be your router is unplug,check it.If it is already Ok now,check now the connection of internet,by going into the control panel and click network connections,it should be connected,if not select the computer icon and right click your mouse then choose enable,the computer icon should be in light blue color,it means your connected.
test all power and data leads that attach to your hard drive the leads from your
((motherboard to your hard drive)) Sata make sure they have dust free secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as a faulty fan lead can cause you problems a computer needs all of the power and data to travel through every working device and to
have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
hope this helps
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no?MOISTURE in the air line dust causes static to build up in a computer causing it to overheat any many other problems
Test all leads that attach to your hard drive including electrical extensions DE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they
could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer errormake sure there is no dust in and your graphics card
hope this helps
