1Go to Account Setting------- 2.then Security setting 3.Click on Deactivate your Account4. Enter your password and Captcha field 5.Your account is Deactivated nowor if you wan tot permanently delete your account then visit this pagehttps://www.facebook.com/help/contact.php?show_form=delete_account best of luck
There should be a switch towards the bottom on the right hand side
Setting ring time switch
The ring time/toll saver switch allows you to set the
number of rings the caller hears before the answering
system plays your outgoing message. You can set the
switch to answer af ter two rings or af ter four rings.
Once the greeting has star ted, you can stop it when
you pick up the call at the handset or base.
In the TS (Toll Saver) position, the answering system
picks up af ter two rings if you have new messages,
and af ter four rings if there is none. This way, if you
call long distance to check your messages, you can
hang up af ter the third ring to avoid billing charges.
In addition to what 'TERESACONSTA' said after you go to Setting, select Time and Date, if Autoupdate is on,take it off: this will open the sub menu to with;
dude on the device u want to pair. then go tu bluetooth connectivity menu of ur cell and go fr my devices. ter search fr ur device and add it ter.. ter u go ready to use...
modem to inter net or wan port on this router>and u have 4 ether net od lan use any one -->ether net cable to pc's>and if u r using cable inter net then reboot the both router and modem u can get inter net access if its dsl contact linksys cause need to configure teh router rate me solved if its help full thx
