looks as though the user profile might be corrupt. Try booting into safe mode or another user log in. If you can access safe mode create another account. Reboot computer normally and log into the new account. If new account works then you have a corrupt user account that would need to be fixed or just transfer all data to new account and remove old account.
Boot it in safe mode by pressing f8 on start up select safe mode from the available menu, on log on screen change username as administrator leave password blank and press enter you can able to login if you cant means use oph crack cd
This link may help. You can try to do something if it is connected to a computer. If not, you can disconnect the video cable from both end and wait for 5 minutes and reconnect it. After your monitor wake up, use your OSD to disable sleeping mode, hiberation mode or turn off monitor mode within power options.
Is it in sleep mode or hiberating mode? Green or orange lights on the top of the laptop for not fully charge battery or some signal lights for your brand of laptop? If the later, you can check the manual to see what those lights indicates. Otherwise, you may put on the power cord and press the power button to wake it up or restart it. Then set the preference for sleep mode or hiberating mode in control panel, power options. There also could be a hardware issue though. You may need to press on the position of the processor so it will sit firmly on the mainboard and if possible check the connection of cards and hard disks and memories and make sure they are well connected. If there is still an issue, you can try to flash the BIOS, reset the hard disk to factory default according to the manual or there might be an issue with the monitor. Try another monitor connected to the other VGA port of the laptop.
well i think you should download latest cam driver it will solve your problem.it happens because your cam driver does not working properly with your system
