SOURCE: Problem with the MSI 7050
Sorry, I can't find a color diagram. But check page 2 of the HP support manual, this shows all the jumpers and board connectors. You can download the manual from the link below:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00358730/c00358730.pdf
SOURCE: How to hook up the front panel switch for a Quicksilver2-cmt motherboard
You first need to know the make and model number of the motherboard. Most mobo's have the make and model printed on the board itself, other times there will be a sticker.
locate these and let me know what make and model and i can do my best to provide you with the manual.
Thanks,
Brad Nelson
SOURCE: power sw, reset sw, HDD led motherboard connectors
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
97
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If
this Answer goes some way towards helping to resolve your Query, Problem or
Fault, please take the time to Rate it. Doing so helps Solution Providers, like
me, better understand the needs and the point of view of Askers, like you, and
guides us in exploring the best ways to provide the most comprehensive, useful
and high quality Responses and Solutions we can. If you need further help,
please do not hesitate to post another Question or add a Comment to this
Question.
Thanks
for using FixYa.
Connect the front panel leads to the motherboard connector marked "JFP1" using the following pins as indicated by the markings on the motherboard and the front panel leads: HDD LED on Pins 1 and 3; power LED on Pins 2 and 4; reset switch on Pins 5 and 7; and the power switch on Pins 6 and 8.
Good luck.
