You could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical
extensions,IDE,SATA
the leads from your
"((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or
just replace them they could be faulty
make
sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have
secure connections and are not faulty even the electical extensions or just
replace them they could be faulty a computer needs its connections to continue
its cycle and have an end so any faulty leads will end up with a computer error
hope
this helps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this process should enable a complete format
hope this helps good luck
