SOURCE: 20036 hyundai cigarette lighter
fuses on drivers side LHD ,open door and on the end of the dash
There's one under the hood, on the right side... labeled Fuse Box and then there's another on the left side of the steering wheel, near the signals, behind the little fold out compartment (which you have to take out to get at the fuses)
SOURCE: cigarette lighter won't work
The front lighter is powered by fuse 24 in the interior fuse panel and the console power points are fuse 7 and 9 in the battery junction box under hood.
If you have a 12V test lamp you can check the socket for power and check the wire to the socket.The socket may be bad.
SOURCE: cigarette lighter stopped working
the cigarette lighter fuse is in the passenger compartment on right hand drive cars it is next to accelerator pedal under panel on right hand side the fuse is no 32 20 amps
SOURCE: replace cigarette lighter
Review the section ZJ-Secc-8E-Instrument-Cluster-and-Gauges in the page 8E-5 you can find the graphics about this work.
Good luck!!!
the lighter socket may have melted terminals
