Question about Compaq Evo N610C Notebook
Can't connect to internet
Hi! and Help!
I successfully set up Linksys for my Campaq laptop and it was working fine. Now, it says it's connected and signal strength is excellent but when I try to connect to internet explorer, it says that the page cannot be displayed and that I'm working offline. I unchecked working offline in the file but I still cannot get online. I'm a dummy when it comes to such things but my computer savvy 18 year old can't figure it out either. ;)
Thanks!
Sheila
    Problem Solver:
  • 35 Answers
Make sure that your connected. on IE go to tools, internet options. connections and setup on the top. keep going. let me know if u need help.
good luck
cheers
Posted on Aug 13, 2008
My road runner internet works fine, and for years my linksys srx200 wireless has worked great, just yesterday my wireless connection is excellent as always but our laptops all say cannot connect to the...
Hi
If you have an internet connection using the ethernet cable but not on the wireless and there is an orange light blinking.. Try to reset the router by pressing the reset button located on the back or on the location were you can twist the stand for the router. press it for about 10secs and that will return the router on a factory settings. before u reset the router make sure to acces the configuration for the internet settings of your isp provider. if the orange light still there, try to download the latest firmware of your router on linksys site and that should fix the problem
Jun 10, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Just set up my g broadband router. Unable to connect to internet
Your laptop may not support g wireless. Change the wireless to broadcast B and G
Nov 15, 2009 | Linksys Wireless-G WRT54G Router
How can i connect to enternet f i have a linksys wireless g notebook adapter with model no. WPC54g ver. 2
hi
this is a connector to the laptop and now you'll need a source...
a source can be a service provider with wireless connection or a free hotspots or
a home based wired internet connection with wireless router
if you have a wireless router then you may have to call the ISP for the DNS server settings if any required but for others i think the auto IP configuration settings should work fine
cheers
pls rate if this was any help
Jul 07, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys WRT54G not seeing internet connection
spacer335,
Who is your Internet service provider, and do you have cable or DSL? You said you have your PC, Xbox and DVR all hard-wired and working fine; are they currently able to get online while connected directly to the Linksys WRT54G? What devices are you trying to connect wirelessly to your Linksys WRT54G?
If you are currently getting Internet access let's check the wireless settings in your router.
Here are a few things you can do to verify your wireless settings in the Linksys WRT54G:
1. From your hard-wired PC, log into your Linksys WRT54G via the web-based interface. (Open Internet explorer and type 192.168.1.1) Note: this is the default IP address that comes on most Linksys routers.
If that doesn't work, verify your computers current IP address information by going to Start (or in Vista it's simply a windows icon), and selecting Run. Type CMD and hit Ok. Now type ipconfig and hit enter.
The default gateway information is the address of your router and should read something like 192.168.1.x.
Enter that address in Internet Explorer's address bar and hit Go.
2. If you connected successfully you should receive a username and password prompt, again the default username and password that comes with most Linksys devices is admin/admin, however it could be different if you've specified an alternate username/password. If you cannot remember the username/password, your only recourse is to perform a hard-reset of the device by using a small pin and holding the reset button on the back of the router.
3. Once you're in the router's web-based configuration there will be a section for "Wireless Settings" or "Wireless Configuration", or some derrevation. Depending on the version of firmware you have installed on the unit, it may be under Basic Setup or Advanced Setup.
You'll know you've located it when you have see options for SSID, Channel, Wireless Security/Encryption, WEP, WPA, etc.
This section will tell you the name of the signal your router broadcasts (also known as SSID). You can change this to whatever you like, in fact is reccommended you change to something unique so that you can easily identify your network when trying to connect with a laptop. You can also enable wireless security such as WEP or WPA, however for the purposes of troubleshooting let's leave encryption off for now. Once you've made the neccessary changes, select Save or Apply at the bottom of the page to save your changes.
4. Now, again since I don't know what you're attempting to connect wireless I will assume its a laptop with an intergrated wireless adpater, or possibly a USB or PCMCIA wireless adapter. Either way you should see your network (with the new name you've configured) in the list of avialable networks, do you see any networks listed? If the laptop has built-in wireless, is the WLAN switch enabled on the laptop? (Usually a small switch on the front or the side of the laptop indicating WLAN, or sometimes a function/fn key combination)
Hope this helps somewhat, give me some more information about what you're trying to connect wirelessly with and I'll see if I can help you out.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Wifi connects but can't get on the internet
Try going to your network connections, double clicking the wireless connection, then double clicking on TCI/IP Protocol. Make sure that everything is set up to detect settings automatically. If this doesn't work, try unplugging your router for at least 15 minutes then plugging it back in.
Dec 31, 2008 | Dell Inspiron 6000 Notebook
Laptop is connecting to network, but will not connect to internet
have you given you MAC address of the router to ISP (internet service provider) try this. this will solve your problem
Nov 23, 2008 | Linksys Wireless-G WRT54GS Router...
Router just doesn't work?
If the computer works fine when directly connected to the modem, it means to say that your ISP is able to provide you a connection. You might have to access the page of the router via internet explorer (192.168.1.1) and double-check the settings. Check the status tab of the router and see if the router is able to get an IP address from the modem.
Thanks!
Aug 26, 2008 | Linksys Wireless-G WRT54GS Router...
Compaq Evo N610C Notebook Logo
109 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
