The model 40 has a single piece electronic ignition, it cannot be repaired it will have to be replaced, before replacing, check the air gap between the flywheel and the ignition unit, this should be 0.3mm, also diss connect the earth cut out wire from the terminal on the unit and try for a spark again, this will rule out any fault with the wire or the switch, the ignition works off speed of rotation so you will have to crank the start as if you were starting the machine.
