Seems like your primary switch isn't closed correctly or it might bad.
step to trouble shoot
OVEN HAS 5000 VOLTS MOVING INTO IT PLEASE BE CAREFULL
1.press back key to turn off the oven.
2.Open left side pannel.
3.press 'back' and 'enter' key together.Then, enter 9428 and then press enter.
4.You will be directing to an testing screen.At the bottom of thetesting screen there are many alphabets.In which you can see 'P' ,'S' and 'M' .
5.Open the door and watch what happened to alphabet 'P'.I meant to say that when door open alphabet will highlited ,and when closed its seems an regular 'P'
6.open door and close the door .And also keep an eye on the primary switch at the top left corner of the oven where the door latches engaged.If it engaged very nicely and you still see an highlited 'P' in the testing screen then REPLACE THE PRIMARY SWITCH OR IF SWITCH IS OKAY THEN CHEK THE WIRING UPTO MAIN BOARD.
7.If switch doesn't latches properly then adjust switch ,by lossning the screw and aligned it properly.
PLEASE LET ME KNOW IF YOU KNOW HOW TO USE MULTIMETER,SO I CAN EXPLAIN YOU HOW TO CHECK THE SWITCH.
ALSO PLEASE RATE MY ANSWER.
THANKS
