SOURCE: turbochef tornado
This oven has 2 mags in it this error codes explains that one of these are failing.
SOURCE: TurboChef Tornado Door Open?!
check the door switch... also you can try a hard reset ( unplug power) ( if hardwired in you will need to trip the breaker) hope it helps
SOURCE: F3 Mag Curr. on Turbochef Tornado
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
SOURCE: I have NGC tornado Turbochef, it is toasting too
temp should only be no higher than 500 try that
SOURCE: Problems with TurboChef TORNADO Electric Oven f8
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
