go to system set up see if programs if you have a 4 button spa remote disconnect and see if it goes away sometimes they get water in the wiring no programs are stored in the PDA
sounds like a loose wire on the red 4 pin connector to get water temp filter pump must be running lost of times closing crews disconnect that stuff if that doesnt work give me more info
try turning off the aqualink and PDA then turn on the aqualink then PDA if same happens check the 4 pin red plug inside the top panel if plugged in check the wire to the antenna if not cut or loose open the antenna panel to see if red and green lights blinking if not check to see if you can change channels if you cannot get to work put system in service and you can control spa that way
