Hello! We have some problem whith 1 chanel, when 2 tekniks mk1200 II are connected so left chanel have very low sound. What type of problem is in my Vestax Pmc 07 PRO ? I need electronics diagram. We buyed i 2001. Thanks for helping Radek
BOTH turntables and the same channel on each? If it's really really low and tinny that would probably be a failure to have/use a PHONO preamp (built-in and selectable on the Mixer).
Swap the channels coming in from the mk1200 and see if it stays with the mk1200 or with the left channel of the mixer.
There IS an outside chance you have flaky connections at the cartridge.
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
