Volfenhag ZX-7180 Car Audio Amplifier
Problems with Volfenhag ZX-7180 Car Audio Amplifier?
Troubleshooting and Support
Solved Problems for Volfenhag ZX-7180 Car Audio Amplifier RSS Feed Post a New Problem
Can't take apart
How to remove main board
1 Solution
1 channel only works???? plz help
ok i had bridged my amp and then the right chanel dosent work and the left one does what is up with that? also because...
1 Solution
amp protection light
will not go off and speakers are popping
2 Solutions
amplight
protection light will not go off
1 Solution
protection light
amp protection light came on and my 2 12s will not stop making a popping noise.i have tryed all the wires ,fuses,rca,and...
1 Solution
american pro amp 1000 watt vs=3503
the power is on but there is no sound on the sub, when the led greed light is on that means that its on right, what...
1 Solution
window problems
how do you take out and replace a 1994 lincoln window regulator
1 Solution
Unsolved Support Problems
Unsolved Problems for Volfenhag ZX-7180 Car Audio Amplifier RSS Feed Post a New Problem
volfenhag amp that blows fuse
i have an amp that worked great one day and not at all the next morning. it blew its fuse as soon as I put another fuse...
Post a Solution
amp problems converting 4 channels to 2...
recently i had an 4 channel amp in my ride that a local stero shop put in i am running 2 10 inch sony explodes and i...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Amplifier TypeDual Channel
Bass BoostWith Bass Boost
BridgableBridgable
Power Output
RMS Power at 4 Ohms220 W x 2
RMS Power at 2 Ohms320 W x 2
Performance
Bass Boost Frequency100 Hz
THD at Rated RMS Power.03 %
Signal to Noise Ratio97 dB
Frequency Response20 Hz - 20000 Hz
High - Pass Frequency50 Hz - 1000 Hz
Low - Pass Frequency30 Hz - 250 Hz
Dimensions
Depth11.09 in.
Height2.34 in.
Width16.91 in.
Other Features
MOSFET ampYes
3 Way ReadyYes
Sponsored Links
Loading problems.
Top Experts
Ask Me
pbabin Guru
15 solutions
Ask Me
pierre235 Guru
1 solutions
Ask Me
zzedly Guru
4 solutions
Repair Service
Find Car Amplifier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
