Zhone (6218-I2-200) Router Logo
Posted on Aug 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zhone 6218 i have zhone 6218 wireless 4 ports router i installed wrong software for it then it's red lamp kept a light and wireless didn't work till now i tried to reset it again but still have the same problem ..thanx
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1604
Points
Zhone (6218-12-200) I have wifi encrypted to manage 4 passwords. I am having a problem entering 3 additional at 64-bit - keeping in mind each person would be assigned to individual access codes
Anonymous
Level 3:
  • Master 659 Answers
  • Posted on Aug 12, 2008
Anonymous
Master
Level 3:
Answers
659
Questions
Helped
228063
Points
1786
To restore the router to factory default settings, select Management ->
Settings -> Restore Default.
I take it that is what you have tryed?
http://zhone.com/support/downloads/cpe/
try finding the correct firmware to install
2helpful
How do i find the wireless network key for my router
You need to look in the user manual http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
Chapter 2. page 26 Logging in to your router.
Then Chapter 5. page 67 Wireless security.
Follow the instructions.
Am using Windows 7. Just bought a Zhone 6218 Wireless Modem. I have connected it ok. I can access the internet but I cannot access my Wireless signal,
Good day!
if you wish to connect on the wireless connection..you need a software that install on the usb its called wireless usb..
just go to the wizard wireless connection..the wizard teach you how to connect it step by step after that insert the wireless usb to the usb port..
thanks for using fixya..
2helpful
2answers
I have a Zhone router, model number 6218-I4-200-0CL. I'm trying to figure out how to forward a port, but there is no actual "Port Forward" option under the configuration options. There is...
Hi!
Please follow the guide here... It's for a different Zhone model - but it should work exactly the same!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
I NEED TO RESET MY WIRELESS PASSWORD, ZHONE MODEL 6218-12-200-0CL PL SEND INSTRUCTION
YOU CAN RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
Here is the link to official Zhone support site for further detail (if required)
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Can i connect a wrt54g wireless router to a zhone? to get wireless access on my laptop and wired connection to my computer?
s u can connect as u wish. connect a utp cable lan port of ur wireless router to ur pc. assign ip for ur pc with router's ip as gateway address. similarly search for wireless networks from ur laptop. u will find ur wireless router to in that range. click on it connect to the network. the ip gets automatically assigned for the laptop. Thats it u are done!!!
Zhone wireless router 6218 cat5 plug ins'
they shouldnt be "locked" you can try resetting the unit on the back there should be a small button use a paper clip hold the reset down for at least 30 sec while plugged in and try again.
When using utorrent or any other torrent client it says i have problem with my network configuration
You'll need to forward the port you have selected in your BT client (you can set it / checj ut in uTorrent: Ctrl+P -> Connection -> Port used for incoming connections. It should be something between 40000-52000.) to accept incoming connections.
Unfortunatly there is no guide for your router model, but you can help with this one http://www.portforward.com/english/routers/port_forwarding/Zhone/6218-12-200-0TT/6218-12-200-0TTindex.htm, also port forwarding is referenced in your owners manual, so you should check that too.
How to turn zhone 6218-i2 router to wireless, now am using cable?
hi Jeffkrick.
if you go to the link you can read the manual.
when you open this link you will see the pages at the top of the page just click on the pages and it will let you read it.
Zhone 6218 I2 User Manual
2helpful
Zhone 6218 driver
The manufacturer won't have your installation CD because that process is exclusive to your ISP. Check your ISP's website to see if they release their setup software online or contact them to get the required CD.
1helpful
5answers
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Top Zhone Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
