20 Most Recent
Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM TR069 & INT P - 6218-I4-200 Wireless Router Questions & Answers
How to change the routers password
Hey, first go into your computer and go to devices in the network section and click on your router that you want to change the password on. Then go into info and it should have a website for your router when you type this in on your browser now every router is different but once in there you should find your way to change the password
I have a Zhone router, model number
Hi!
Please follow the guide
here... It's for a different Zhone model - but it should work exactly the same!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
How do you open the NAT on this router
You can perform the following steps to open NAT..
1) You can take the IP add of your device( X-box, PS3) and then contact the device vendor(Xbox or PS3) and ask them to give port numbers for your device. Once u get the port numbers you can either open ports on the router by logging into the router interface using your Default gateway(192.168.2.1) of the router or you could put the IP add of your device in DMZ on the router. Basically this will keep the device out of the firewall of the router( Which is the main reason for this issue).
2) If the first step didnt work you could disable the firewall on the router.
If both the steps didnt work you could check if your router has any firmware update or it has to be reset and re-configured and the above steps should be re-done.
Hope this helped.
WIFI PASSWORD
Download a manual for the Zhone 6519 if you don't already have one. (You'll be prompted to set up an account)
Service Support
Connect router to PC by LAN cable then log in through the web interface. Go to wireless settings - you should be able to locate the wi-fi password, pass-phrase or pre-shared key.
