Check fuse first. Check for broken wire where the element plugs in. Unplug the stove from wall ,pull out the element and drip pan , remove the screw and pull the plug out and see if both wires are on. If they are remove the back panel about 6 - 8 screws, check for broken wires to and from the regulator.
Hi
The issue seems to be with pressure regulator that is bad
and should be replaced. Hope this helps...please post back for further
assistance.
Daniel
What is the make and model and type of appliance??
