Ge profile gas oven broiler works but bake wont light
When we turn our oven on bake it wont turn on or light the gas burner. The broiler seem to work and lights like normal. When on Bake the read-out says PRE like it always does but the burner will not come on. Also the stove top works ok & the oven light works ok.
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Jim your ignitor has gone bad once again. You can turn off the gas supply,remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor. Place a clamp on amp meter over one wire of the ignitor and turn the control on for bake. If the ignitor does not glow at all. It is bad. If it glows and reads 3 amps or less on the amp meter it is still bad. A proper functioning ignitor will light and re-light the burner in 45 seconds or less.
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
