I am using metalic thread and it keeps breaking in the middle of the machine. How do I regulate the tension on a ellure babylock? I think I need to loosen the tension a bit
When a bird's nest of threads appear either on top or underneath your fabric, the likely culprit is your upper thread tension. If loops appear on the underside of the fabric, the upper tension may be too loose. And if knots appear on the top, the upper tension may be too tight.
Your options are limited on the BabyLock Ellure. You may be able to use a heavy thread in the bobbin but probably not in the needle. Most heavier threads will not feed through these machines and are used for surface embellishment with a cording or zigzag foot.
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
try changing the needle check for burrs on the needle plate and in the bobbin area if the problem persists then the machine may have to be checked again
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
I have the same machine and love it. Sometimes if the thread is old that will happen to me. And also I spray the thread with static guard before i thread the machine in dry cold weather. Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool. I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it. I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
I'm not sure which thread you are referring to, its either the bobbin thread (under) or the needle thread (above.top) I'm sure you can find some helpful advise here on the baby lock site http://www.babylock.com/support/faq/?FAQ=10
